Date/Time: Sun, 24 Nov 2024 08:24:31 +0000
[Programming Help] - Can you send me a formula to so i can set alerts for numbers bars(footprint)
View Count: 158
[2024-06-12 22:11:20] |
cjmitch111 - Posts: 6 |
Can you set it so that it alerts when there are 3 imbalances in a row inside the body of a candle after it closes for both a bull and bear candlestick. I currently use Volume at price indicator to highlight imbalances but idk how to set it to only highlight imbalances inside candlestick body and after it closes. And is there a way to set it so that only -delta imbalances are highlighted in bear candlesticks and +delta imbalances in bull candlesticks.
Date Time Of Last Edit: 2024-06-12 22:15:01
[2024-06-13 14:35:34] |
What you are asking for is more than we can put together for you. But here are some pointers to help. - With the "Volume at Price Threshold Alert v2" you can set a "Highlight Adjacent Alerts Minimum Group Size" that will give you an indication when you have the 3 imbalances (or more) together. The Subgraphs that hold that information start at Subgraph 49 and each is a pair that defines the low and high of a group. Just be aware that SG49 is always set, so you want to use SG50 to know if there actually is a grouping in place at all (i.e. SG50 will be non-zero if at least 1 group exists). - You would have to compare these subgraphs to the Open/Close values to determine if it is inside the body of the bar. - You would have to check the delta value against the bar type as another aspect of the alert. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
