Date/Time: Thu, 19 Sep 2024 22:00:12 +0000
RENKO gaps still there, even on SC feed
View Count: 922
[2014-08-22 09:51:24] |
ripsdips - Posts: 143 |
I did as you recommended which is switching over to your data feed and the gap on RENKO is still there. http://www.sierrachart.com/image.php?l=1408701004299.png |
[2014-08-22 10:13:03] |
Effectively nothing has changed because you are looking at the same chart for the symbol. You need to open a new chart through File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
