Date/Time: Thu, 24 Sep 2026 07:16:33 +0000
Wick Test Indicator
View Count: 2081
| [2024-06-12 13:56:49] |
| User104190 - Posts: 1 |
Hi, I was wondering how I can apply this indicator to my charts - it highlights what is called the 'wick test' so when price moves past and then retraces it flags when there is an untested wick/candle to enter. Any help will be much appreciated.
Attachment Deleted. |
| [2024-06-12 16:14:39] |
| John - SC Support - Posts: 47994 |
We do not think we have a study that does this exactly, but to be honest, we have 500+ studies, so we do not know every single one of them. Take a look at our list of studies and see if there might be something that matches what you are looking for - particularly under a different name, as we checked for "Wick" and there are no studies that have this in the name: Technical Studies Reference You can also see if you can create what you are wanting from the Alerts. Refer to the following: Study/Chart Alerts And Scanning For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-07-03 16:38:53] |
| User429142 - Posts: 49 |
You are looking for the Volume Value Area Lines study.
