Date/Time: Thu, 19 Sep 2024 21:53:07 +0000
Changing data provider
View Count: 1014
[2014-08-22 09:41:09] |
ripsdips - Posts: 143 |
as per your recommendation, I will change from IQ to your FX provider. Can this be done by just going to data trad settings and picking from the dropdown? If yes, which one is Sierra Charts?
[2014-08-22 10:15:03] |
Yes you just select it from the Global Settings >> Data/Trade Service Settings >> Services list. It is named "SC Forex Data (FXCM)".
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-22 10:17:39
