Date/Time: Sun, 24 Nov 2024 08:27:50 +0000
Font issues in the new "Text Properties" pop-up
View Count: 211
[2024-06-12 05:36:45] |
Rainer - Posts: 109 |
The *new* >>Text Properties<< pop-up DOES NOT accept/apply ANY Font changes nor keep Font settings. Issue, the … Font (Action) - Font-Name change, change font-Size, change font-Color = is not working = and does not accept any Font-changes, … since ver. 2643+ incl. 2645 latest pre-release rev. 50413; see attached. note1: when toggle “Use Drawing Specific Font” Yes or No, = it has no effect to the above issue. note2: when click "Chart Drawing Properties", for a micro-second the old (windows) 'Text Properties-dialog box' pops-up first and disappears (in a brief flash), then only the new >>Text Properties<< box displays. Hence … right now (& since 2643), I no longer can make any *Font changes* to Drawings including all written on-chart text; for now, needed to roll-back to ver. 2642 Is this still a bug, (a windows bug?), or is there a different setting? |
Attachment Deleted. new Text Properties pop-up Issue.jpg / V - Attached On 2024-06-12 04:43:55 UTC - Size: 413.78 KB - 54 views |
[2024-06-12 14:30:59] |
This is being looked into.
[2024-06-14 14:04:32] |
Sierra_Chart Engineering - Posts: 17154 |
To resolve this update Sierra Chart to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
