Date/Time: Thu, 19 Sep 2024 21:29:22 +0000
is the renko chart suppose to show these type of gaps
View Count: 978
[2014-08-22 09:10:55] |
ripsdips - Posts: 143 |
is the renko chart suppose to show these type of gaps http://www.sierrachart.com/image.php?l=1408698554734.png |
[2014-08-22 09:28:04] |
You are looking at a chart which contains numerous faulty timestamps from IQ Feed. We recommend using the Sierra Chart Forex Data Feed instead: Sierra Chart Real Time and Historical Forex and CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-22 09:32:09] |
To confirm what we are saying merely look at the timescale at the bottom of the chart. You will notice the dates are repeating.
