Date/Time: Thu, 19 Sep 2024 21:47:13 +0000
Best method to adjust to different daylight saving time (DST) in Europe and US
View Count: 1288
[2014-08-22 07:31:56] |
Bango - Posts: 76 |
Hello! What is the best method to keep data in good standing as DST ends in Europe earlier than US? Is it sufficient to set Time Zone for every chart/symbol? Better having two copy of SC running with different global time zone? Thanks |
[2014-08-22 09:48:53] |
Sierra Chart has a global time zone setting and a time zone setting for individual charts. This is fully documented on this page: https://www.sierrachart.com/index.php?page=doc/doc_TimeZone.html So you can use a different time zone for each chart if you need to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
