Date/Time: Sun, 24 Nov 2024 08:37:53 +0000
Number bars
View Count: 175
[2024-06-11 08:32:30] |
SafSaf - Posts: 89 |
Hello you clever lot in the support team, I like to use the number bars to accompany my charts, namely the volume of buyers and volume of sellers, per bar. However, something that would be really useful would be to see the percentage difference between both also but I can’t seem to find how to include that and I’m sure it must be an integral feature because it’s such a simple calculation?
[2024-06-11 10:55:27] |
VLiviu - Posts: 223 |
See attached, I think its what you are looking for
DiffPercent.png / V - Attached On 2024-06-11 10:55:23 UTC - Size: 89.85 KB - 46 views |
[2024-06-11 11:31:01] |
that may be the one thank you.... however, lets say the buyer vol was 1 and the seller was zero, i would expect the percentage to be 50% in the green. on my chart that exact combination shows 1% in the green which is odd for a non mathematician like me
[2024-06-11 15:16:42] |
It sounds like you have the Input for "Use Default Number Formatting for all Subgraphs" set to "Yes". If you set this to "No", then you will see the values with two decimal places. Refer to the information for this Input in the following section: Numbers Bars: Numbers Bars Calculated Values Input Descriptions Also, be aware of the Input for "Display Percent Values as Decimal or Percentage". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
