Date/Time: Sun, 24 Nov 2024 08:29:37 +0000
Limiting Bars to Load
View Count: 172
[2024-06-11 08:06:27]
User428777 - Posts: 13
I am trying to load charts with only 20 days, but when I open a new symbol it proceeds to load a year's worth (!!) of data and takes awhile. How can I fix this issue? I have attached a photo of my settings.
imageCapture.PNG / V - Attached On 2024-06-11 08:04:02 UTC - Size: 67.94 KB - 39 views
[2024-06-11 12:22:53]
I have attached a GIF documenting the issue. I have it set to 10 days on a 5m chart and it proceeds to download data from 2023.
imagechart.gif / V - Attached On 2024-06-11 12:22:15 UTC - Size: 1.99 MB - 45 views
[2024-06-11 12:56:42]
User431178 - Posts: 541
Data/Trade Service Settings: 1-Tick Data (Global Settings >> Data/Trade Service Settings >> Common Settings >> Maximum Historical Intraday Days to Download)
Set the above to a lower number, does that help?
[2024-06-11 13:17:39]
It did not work.. I did another capture. Every time I want to change to a new symbol this issue occurs. Frustrating when you are a daytrader!
imagecapture.gif / V - Attached On 2024-06-11 13:17:22 UTC - Size: 2.8 MB - 53 views
[2024-06-11 15:23:57]
The setting referenced previously is the one that controls how much data is initially downloaded for a symbol that has not had data previously downloaded. What are these settings - "Global Settings >> Data/Trade Service Settings >> Common Settings >> Maximum Historical Intraday Days to Download" set to?
