Date/Time: Sun, 24 Nov 2024 08:32:14 +0000
Custom Drawing Tool Settings Window
View Count: 171
[2024-06-10 22:38:25] |
User547290 - Posts: 58 |
Wanted to let you know of a bug that would be nice if you fixed. When setting up a custom drawing tool in the control bar the "Custom Drawing Tool Settings Window" will not close. The only way to close it is to restart SC. Just a bit of a pain. Also your adding text to tools is kinda messed up. ex: adding text to an arrow, the placement of the text is pretty wonky. I've made work around's but maybe you can fix it in the future. |
[2024-06-11 14:20:40] |
This was a problem that was fixed awhile ago, and we are not able to reproduce it in the current release. Please make sure you are on the the current release. If you are running sub-instances, make sure to restart them so they are updated to the current release as well. To update, follow these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
