Date/Time: Sun, 24 Nov 2024 08:19:35 +0000
Modify Text on Drawing Object Bugged in 2644
View Count: 226
[2024-06-10 22:27:05]
User450463 - Posts: 122
When you select "Modify Text" from the drawing context menu, an enormous textbox (large enough to type the first 4 books of the bible in) opens, but the cursor is not placed in the giant textbox. You have to click in it to get focus.
This is not how it has worked for years. Also, just a matter of opinion, the small, discreet text box that used to display is much more professional looking. But at least put the cursor in the giant textbox so the user can start typing without having to click it.
Date Time Of Last Edit: 2024-06-10 22:29:31
[2024-06-11 18:14:07]
User688525 - Posts: 257
With the latest update, the text field is no longer automatically selected with "Modify Text" for a drawing.
[2024-06-11 20:10:47]
Sierra_Chart Engineering - Posts: 17154
We will address these items. That edit box will have a default size and be resizable.
[2024-06-13 15:57:39]
This will all be resolved in the next release coming out today.
[2024-06-14 02:19:33]
Tested and working correctly in the latest 2646 version. Thank you for the prompt fix!
