Date/Time: Sun, 24 Nov 2024 08:42:15 +0000
Numbers Bars Calculated Values
View Count: 196
[2024-06-10 18:04:34]
User709203 - Posts: 4
I would like to have a ratio of positive delta sum and negative delta sum expressed as a percentage. If I could do that on my own please give me guidance on how I could go about it.Thank you.
[2024-06-10 18:26:05]
There is not a way to have this in a Numeric Table like the Numbers Bars Calculated Values, unless you create a custom program. Refer to the following if you want to go this route:
ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type
What you can do, however, is to perform the calculation you want using either the Arithmetic Studies or the Spreadsheet Formula study. Refer to the following:
Using the Basic Arithmetic Studies
Spreadsheet Formula
Then display the value as a number by setting the "Draw Style" for the final study to "Value of Subgraph" and setting the Width/Size to a value that is readable (typically 8-12). Refer to the following:
Chart Studies: Value of Subgraph (ACSIL: DRAWSTYLE_VALUE_OF_SUBGRAPH)
Chart Studies: Subgraphs Tab >> Line Width
Then finally, in order to get the values to show in a single line, adjust the scale to be very wide, so the numbers will appear to be in a single line.
