Date/Time: Sun, 24 Nov 2024 09:03:25 +0000
Sierra Chart is missing Menu Bar
View Count: 161
[2024-06-10 17:52:52] |
User920356 - Posts: 1 |
My Sierra Chart is missing the Windows Menu Bar (File, Edit, Chart, Analysis ....) How do I get that back? RP |
Screenshot 2024-06-09 215618.png / V - Attached On 2024-06-10 17:52:46 UTC - Size: 392.75 KB - 39 views |
[2024-06-10 19:42:52] |
It must be under your Taskbar at the top of your screen. If you can, move Sierra Chart down a little to find the menus.
