Date/Time: Sun, 08 Sep 2024 00:16:24 +0000
Stationary text
View Count: 148
[2024-06-10 16:03:41] |
User499894 - Posts: 45 |
Hi, I find the new Stationary Text tool quite worse than how it used to be: Before I could place the text very precisely (exact distance from X or Y axis), now I can only move it around with the mouse; selected colors (for text & background) and font+size of text do not work at all (or maybe I do not understand how to change them?).
[2024-07-02 23:30:42] |
Sierra_Chart Engineering - Posts: 16292 |
There is not a new Stationary Text tool. The user interface for modifying it has changed. The issues with that are now all resolved. Update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
