Date/Time: Sun, 24 Nov 2024 08:59:06 +0000
How to prevent VA, TPOC lines from disappearing on a TPO graph when going back in time.
View Count: 162
[2024-06-10 15:42:26] |
User883596 - Posts: 4 |
Hello! I have the following issue with my TPO chart. The VAH, VAL, and VPOC lines disappear from the last TPO when I go back on the time axis. I don't know how to solve it. Please watch the attached video to understand what is happening. I would like to have all the lines fixed, without variation when I slide to the right or left. Thank you!
[2024-06-10 16:03:56] |
Please get us that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-10 17:17:31] |
Hello, attaching the chart here. Thank you!
[2024-06-10 19:24:19] |
The reason why you are seeing what you are is that you have the "Chart >> Lock Fill Space" enabled. Since TPO charts are special, you are only seeing the lines disappear at the location of the lock fill space, whereas the TPO profile itself does not get affected by the lock fill space option. Refer to the following: Chart Menu: Lock Fill Space (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-11 06:50:56] |
Thank you John for your time! Have a nice day. Great support
