Date/Time: Sun, 24 Nov 2024 08:44:01 +0000
Hide Window
View Count: 197
[2024-06-10 13:36:06] |
nicktrader - Posts: 709 |
In my chartbooks, some windows are set to Hide. I have to look for them in CW. Is it possible that there is a “hint” for “Hide”? Many thanks |
[2024-06-10 15:07:59] |
We are not sure what you are looking for. If you "Hide" a window, then the only way to get it back is through the "CW" menu. Refer to the following: Window, CB and CW Menus: Hide Window (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-10 17:58:53] |
John, I know. But it would be helpful, if I could see (by a notice or similiar) what window(s)/ chart(s) of the listed ones are hidden. If there (e.g.) are >20 Charts are listed and two are hidden ... a short notice would be helpful... Many thanks. |
[2024-06-10 19:50:59] |
In the CW menu it does have an item that denotes "Hidden" for the hidden charts.
[2024-06-11 03:43:40] |
John, pls see pic. The charts marked in blue have been “Hidden”. Unfortunately, I do not see a corresponding item. Many thanks |
Hidden Window.png / V - Attached On 2024-06-11 03:42:29 UTC - Size: 16.86 KB - 34 views |
[2024-06-11 14:50:15] |
The reason why "Hidden" is not showing is that the chart title is too long, and the word "Hidden" is placed on the right side of the rest of the information. We do not know when we can do anything about this, but we have taken note of the request. We can not say when we would get to any particular item. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
