Date/Time: Thu, 19 Sep 2024 21:36:06 +0000
DOM price value
View Count: 931
[2014-08-21 20:21:09] |
bwalks123 - Posts: 122 |
I am reorganizing my S&P emini ES DOM columns and was curious if there is a way to not show the full price value so that the column is not so wide. Example in the DOM right now the ES is reading 1989.50 can I set it so I only see the 89.50 and eliminate the 19?
[2014-08-22 02:33:15] |
No. This is not supported.
