Date/Time: Sun, 24 Nov 2024 08:45:04 +0000
Live Data
View Count: 166
[2024-06-10 02:35:57] |
GavinNgo - Posts: 1 |
After following the documentation on connecting to a live feed, I am still missing something as my data is still delayed by 10 Minutes. I have connected my AMP to my Sierra with deposited funds already and have purchased package 11. Are you able to take a look to see what I am missing in order to see live data for ES and NQ futures? Thanks. |
[2024-06-10 14:30:50] |
Everything on your account looks good on our end. We would need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
