Date/Time: Sun, 24 Nov 2024 08:23:05 +0000
Can't delete chart menu data
View Count: 149
[2024-06-09 21:37:25] |
cmack1011 - Posts: 51 |
For the life of me, I cannot find the links to delete the chart menu data that runs along the top edge of chart (pls see pic) Thx
Screenshot 2024-06-09 at 16.34.52.png / V - Attached On 2024-06-09 21:36:28 UTC - Size: 29.64 KB - 37 views Attachment Deleted. |
[2024-06-10 13:28:19] |
Some of that is controlled by the following: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) The other part of it is the display of the information for studies that are in that region. Refer to the following regarding how to show/hide that information: Chart Studies: Subgraphs Tab >> Display Name and Value in Region Data Line Chart Studies: Subgraphs Tab >> Display Study Subgraphs Name and Value - Global Chart Studies: Subgraphs Tab >> Display Study Name Chart Studies: Subgraphs Tab >> Display Input Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
