Date/Time: Sun, 27 Sep 2026 09:23:58 +0000
Contract rollover identification
View Count: 1392
| [2014-08-21 19:17:56] |
| vectorTrader - Posts: 86 |
Is there a way to get the contract expiry/rollover out of Sierra chart? I would like to use it to identify the rollover date? It would be nice to have especially for starting and marking the beginning/end when with various inidciators just a vertical line and VWAP, VbP and TPO. thanks |
| [2014-08-22 02:01:03] |
This is programmed in the Global Symbol Settings: Global Symbol Settings Refer to the Rollover tab. You should also be aware of Chart >> Show Rollover Dates which can be used with Continuous Futures Contract charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
