Date/Time: Sun, 24 Nov 2024 08:40:23 +0000
Trading Activity log Empty
View Count: 257
[2024-06-09 12:52:59] |
User513390 - Posts: 49 |
I am using CQG simulated account, i click everything according to the guidelines. Help me find out what i'm doing wrong. Best regards Rodney |
20240607_102511.jpg / V - Attached On 2024-06-09 12:51:47 UTC - Size: 7.02 MB - 58 views |
[2024-06-09 22:05:51] |
You are on the "Period Stats" tab, but you have the setting for "Period Stats Tab Period Type" set to "Period - None". Therefore no data will show. Change that setting to the period type you want to view.
[2024-06-10 07:42:51] |
If i'm on Live Trading with GCQ, "Period Stats Tab Period Type" set to "Period - None" will work or should i still use period type
[2024-06-10 14:43:19] |
It doesn't matter whether you are live or not. If you have "Period - None" set then you will not see any data in the "Period Stats" tab.
