Date/Time: Sun, 24 Nov 2024 08:52:56 +0000
Denali Feed during Trial?
View Count: 195
[2024-06-09 10:18:35] |
User976 - Posts: 8 |
Hi Sierra Team! I am not 100% sure if it's allowed, but can I have real-time CME Futures Data during the Free Trial (for free)? (I never used the Denali Feed). I would love the Denali since I'll be using that after the Trial is over. Is that possible? Thanks guys! Is it from this link? Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* |
[2024-06-09 21:56:33] |
Unfortunately, no. Although there is a "free trial" of the CME Group data - meaning that you will not pay for the remainder of the month in which you first activate an exchange for the CME Group - you can not get the real-time data for any of the exchanges from our Denali Exchange Data Feed unless you are on one of the "Integrated" packages. While you are on a trial, you simply can not connect to real-time data or trading services, including our own real-time Denali Exchange Data Feed. Note that the Delayed Streaming data that we have available is the exact same as the real-time data, only delayed by 10-15 minutes, depending on exchange. So if you work with the delayed streaming data, you will have the same experience with the real-time data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-09 22:43:29] |
Sierra_Chart Engineering - Posts: 17154 |
Also refer to: Delayed Exchange Data Feed: Using Delayed Data to Evaluate Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
