Date/Time: Sun, 24 Nov 2024 08:21:20 +0000
Trading Evaluator with real time data + AMP
View Count: 178
[2024-06-09 09:28:57]
User447246 - Posts: 3
i would like to use the trading evaluator mode with real time data and AMP broker.
This is what i did:
- change from package 3 to package 10
- activate Denali Exchange feed
- activate full CME real time data (5.5 USD month)
- finish paperwork: non prof agreement etc.
- asked AMP for CQG credentials which i have now (Teton not supported)
But how connect to AMP with my AMP credentials for the reduced costs real time data?
I read all the instuctions but sorry need some step by step advice.
I´m confused :-)
Thanks for help
Thomas
Date Time Of Last Edit: 2024-06-09 09:29:44
[2024-06-09 21:48:54]
In order to connect to AMP where you are using CQG for your order routing, follow these instructions:
CQG Trading Platform Service: Setup Instructions
Once you have made a good connection then your "Verified Until" date will update to 30 days in the future and you will have access to the CME Group data for which you have active exchanges.
You can view your "Verified Until" date at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
