Date/Time: Sun, 24 Nov 2024 09:06:13 +0000
Restarting TPO letters at the start of each Profile Time Period.
View Count: 226
[2024-06-08 15:20:12] |
cmack1011 - Posts: 51 |
I'm currently setting up a TPO with each Profile Time period being 15 minutes. However, I cannot get the block letters to restart with "A" at the start of each 15 min Profile Time Period. IOW's, I would like to have each 15 min TPO profile start with "A". Currently, "A" starts one profile but then runs all the way to "x" across multiple profiles before starting with "A" again. I want to start each and every 15 min profile with "A". Please advise. Thx
Date Time Of Last Edit: 2024-06-08 18:41:16
[2024-06-09 01:05:37] |
Sierra_Chart Engineering - Posts: 17154 |
This is not supported.
[2024-06-09 21:04:34] |
Can a similar thing be done with coloring the blocks for each time period within the 15 min profile so that the first period within each profile is the same color, second period within each profile is the same color, etc, etc?
[2024-06-10 13:24:06] |
If your periods happen to be a multiple that goes into 18, then you can adjust the colors such that they will repeat as you want. But otherwise, since the colors are set to 18 different colors, there is no other way to do this.
