Date/Time: Thu, 19 Sep 2024 21:42:12 +0000
Linear Regression End Channel - Scroll Back
View Count: 1241
[2014-08-21 18:00:06] |
User85481 - Posts: 2 |
Is it possible to have the Linear Regression End Channel renew itself as we scroll back on a chart. Currently once you scroll past the set study number of Bars or Start Date Time it no longer appears on the chart. (increasing the study number or Start Date Time is not the remedy in this case). I would like it so that this study always refreshed as per the set study number of bars, so that it's always current and appropriate to the chart's far right as displayed on screen as I scroll back, regardless of how far I scroll back. |
[2014-08-21 18:15:23] |
This is not technically possible.
