Date/Time: Sun, 24 Nov 2024 09:17:50 +0000
Export to spreadsheet
View Count: 158
[2024-06-07 18:54:39] |
User674409 - Posts: 24 |
How do you export the data of a specific number bar to a spreadsheet ? What I want is to export just the data of one bar, and just the contracts showed as in the picture, nothing more. I need to make my analysis after market. So I can have just two columns in my spreadsheet, thanks
Attachment Deleted. Captura de pantalla 2024-06-07 a la(s) 12.46.05.png / V - Attached On 2024-06-07 18:53:21 UTC - Size: 10.62 KB - 33 views |
[2024-06-07 19:04:27] |
The best option for this is to create a custom study. Refer to the following: ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar List of Third Party Sierra Chart Study and System Programmers Otherwise, what you need to understand is that the Bid and Ask data is only available through Alert functions. Refer to the following: Study/Chart Alerts And Scanning: Special Functions The Spreadsheet Formula study, despite its name, uses the Alert syntax, so you can use this study to get a specific level of a specific bar, but there is not a good way to get the entire bar's data - you would have to add multiple Spreadsheet Formula studies to get an entire bar's worth of data. Refer to the following: Spreadsheet Formula For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
