Date/Time: Sun, 24 Nov 2024 09:41:09 +0000
Order allocation needs to be enabled every time
View Count: 152
[2024-06-07 14:20:32] |
User518877 - Posts: 1 |
Order allocation works fine. However, I need to enable it every time I reboot my computer. I only have one chart and one symbol. There is no other change to the chart when I open and run Sierra. Can you please advise on how to resolve this?
[2024-06-07 16:30:17] |
Sierra_Chart Engineering - Posts: 17154 |
Refer to this setting: Global Trade Settings Windows: Disable Order Allocation To Trade Accounts on Chartbook Opening (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
