Date/Time: Sun, 24 Nov 2024 09:39:08 +0000
Data load
View Count: 149
[2024-06-07 13:40:51]
User710829 - Posts: 16
When I open SC at say 9:28, I can only see the data from then and forward because i’m thru interactive brokers. How do I see the previous data to complete the footprint chart? say 9:00 and on for example. thanks
[2024-06-07 16:45:52]
You can try to download the missing data by following these instructions:
And check the setting for "Global Settings >> Data/Trade Service Settings >> Main Settings >> Maximum Historical Intraday Days to Download Limit" and make sure it is not set to a number like 0 or 1. The default is 7.
But you may not get the data. In which case, the only solution would be to use our Denali Exchange Data Feed for your data rather than Interactive Brokers. Refer to the following:
Date Time Of Last Edit: 2024-06-07 16:48:18
