Date/Time: Sun, 24 Nov 2024 09:29:51 +0000
Instrument value not correct in order ticket.
View Count: 141
[2024-06-07 13:24:14] |
knarf01 - Posts: 48 |
Hello support! I am having an interesting issue.. For some reason my monetary value for points is not calculating correctly.. For example I am currently up 38 points on NQ and my order ticket shows me as -21 points, my account balances are fine, and when I look at some charts where I am showing open positions its also fine but I use the order ticket window mostly. I have had this issue for weeeeeeeks now. Things i've tried.. deleted the custom symbol settings from my folders, updating from the server without any universal boxes checked, deleting again.. I know that the issue has to be related to me switching from Teton order routing, to Rithmic and CQG as well as that I trade NQ and MNQ and ES and MES using the "use as trade symbol only option". Do we know how to fix this? Is there a way to reset this correctly so it uses the data from the server? Sometimes when it "works" it's showing me Micro $ value but the correct points even though I am trading minis.. Thanks a lot team! |
[2024-06-07 16:23:39] |
It sounds like you do not have the correct "Currency Value Per Tick" set when you are using a "Trade and Current Quote Symbol". Refer to the following: Chart Settings: Updating Currency Value per Tick for Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
