Date/Time: Thu, 24 Sep 2026 06:57:29 +0000
CTS T4 demo account
View Count: 1358
| [2014-08-21 16:20:47] |
| bwalks123 - Posts: 122 |
I have a CTS T4 demo account running right now with ES contract chartbook which is working great but when I try to build a new chartbook for say Gold GC or CL contract it does not recognize the symbole? It seems like only the eminis and treasuries are loading data?
| [2014-08-21 17:17:56] |
Restart Sierra Chart an open a chart for one of the listed GC symbols and then post a copy of the Message Log by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-08-21 18:21:47] |
Here is the message log after trying to load GC chart Software version: 1174 | 2014-08-21 11:06:01 Usage end date: 2014-08-24 | 2014-08-21 11:06:01 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-08-21 11:06:01 Active service: CTS T4 FIX | 2014-08-21 11:06:01 Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-08-21 11:06:01 2014-08-21 11:06:01 Local computer clock time | 2014-08-21 11:06:01 2014-08-21 18:06:01 GMT time | 2014-08-21 11:06:01 2014-08-21 11:06:01 Time zone adjusted time | 2014-08-21 11:06:01 Time difference to server time: 5 seconds. | 2014-08-21 11:06:01 Program path: C:\SierraChart\ | 2014-08-21 11:06:01 Data Files path: C:\SierraChart\Data\ | 2014-08-21 11:06:01 OS Version Number: 6.1 | 2014-08-21 11:06:01 Checking for new symbol settings for cts | 2014-08-21 11:06:01 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-08-21 11:06:01 HTTP connection to www.sierrachart.com:80 (1064) | Connected. | 2014-08-21 11:06:01 Notice: 3 days of full use Remaining. If you would like to continue full use the software and services, | 2014-08-21 11:06:01 purchase more usage time by selecting 'Help >> Add Usage Credit' on the menu. | 2014-08-21 11:06:01 Symbol settings are up-to-date for cts | 2014-08-21 11:06:01 Volume By Price study: Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-21 11:06:04 Volume By Price study: Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-21 11:06:04 Volume By Price study: Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-21 11:06:04 Volume By Price study: Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-21 11:06:04 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-08-21 11:06:06 CTS FIX - Firm: Dorman | 2014-08-21 11:06:06 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2014-08-21 11:06:06 CTS FIX socket (1600) | Connected. | 2014-08-21 11:06:06 CTS FIX socket (1600) | Starting SSL connection. | 2014-08-21 11:06:06 CTS FIX socket (1600) | SSL connection established. | 2014-08-21 11:06:08 CTS FIX: Sending the Logon message. | 2014-08-21 11:06:08 CTS FIX: Connected to data and trade server. FIX version: 4.3.10.0 | 2014-08-21 11:06:08 Volume By Price study: Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-21 11:06:08 Volume By Price study: Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-08-21 11:06:08 CTS T4 FIX | Starting real-time market data updates for: ZN.20140900.CME_F. ID: 1 | 2014-08-21 11:06:08 Intraday data recording state for symbol ZN.20140900.CME_F is set to pending. | 2014-08-21 11:06:08 HD Request # 2 | Downloading Intraday chart data for ZN.20140900.CME_F to the file ZN.20140900.CME_F.scid. Service: cts | 2014-08-21 11:06:08 HD Request # 2 | Download start Date-Time: 2014-08-21 09:21:02.0 | 2014-08-21 11:06:08 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2014-08-21 11:06:08 CTS T4 FIX | Starting real-time market data updates for: ES.20140900.CME_Eq. ID: 2 | 2014-08-21 11:06:08 Intraday data recording state for symbol ES.20140900.CME_Eq is set to pending. | 2014-08-21 11:06:08 CTS FIX: Received Account List collateral report. | 2014-08-21 11:06:08 CTS FIX: Subscribing to account: BW* | 2014-08-21 11:06:08 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2014-08-21 11:06:08 CTS FIX Historical Data socket (284) | Connected. | 2014-08-21 11:06:08 CTS FIX Historical Data socket (284) | Starting SSL connection. | 2014-08-21 11:06:08 CTS FIX Historical Data socket (284) | SSL connection established. | 2014-08-21 11:06:08 CTS FIX Historical Data: Sending the Logon message. | 2014-08-21 11:06:09 CTS FIX Historical Data: Connected to Historical data server. | 2014-08-21 11:06:09 CTS T4 FIX | Sending security definition request for symbol ES.20140900.CME_Eq | 2014-08-21 11:06:09 CTS T4 FIX | Received matching security definition for symbol ES.20140900.CME_Eq. Subscribing to data. | 2014-08-21 11:06:09 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2014-08-21 11:06:09 CTS T4 FIX | Sending security definition request for symbol ZN.20140900.CME_F | 2014-08-21 11:06:11 CTS T4 FIX | Received matching security definition for symbol ZN.20140900.CME_F. Subscribing to data. | 2014-08-21 11:06:11 CTS T4 FIX | Received matching security definition for symbol ZN.20140900.CME_F. Requesting historical data. | 2014-08-21 11:06:11 HD Request # 2 | Requesting historical Tick data for ZN.20140900.CME_F from 2014-08-21 00:00:00 to 2014-08-21 00:00:00 (US Central Time). | 2014-08-21 11:06:11 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2014-08-21 11:06:11 HTTP connection to www.sierrachart.com:80 (1064) | Closed. No error. | 2014-08-21 11:06:11 HTTP connection to www.sierrachart.com:80 (1064) | Shutdown and closed. | 2014-08-21 11:06:11 CTS FIX: Received Account Update collateral report. | 2014-08-21 11:06:13 CTS FIX: Requesting Open Orders for account: BW* | 2014-08-21 11:06:13 Requesting market depth updates for: ES.20140900.CME_Eq if supported. | 2014-08-21 11:06:13 Requesting market depth updates for: ZN.20140900.CME_F if supported. | 2014-08-21 11:06:13 CTS FIX: Received Account List collateral report. | 2014-08-21 11:06:13 HD Request # 2 | Receiving Intraday data for ZN.20140900.CME_F starting at 2014-08-20 15:00:00 | 2014-08-21 11:06:15 HD Request # 2 | Timestamp of first Intraday data file record written: 2014-08-21 09:21:03 | 2014-08-21 11:06:16 HD Request # 2 | Total records received: 121976 | 2014-08-21 11:06:16 HD Request # 2 | Requesting historical Tick data for ZN.20140900.CME_F from 2014-08-22 00:00:00 to 2014-08-22 00:00:00 (US Central Time). | 2014-08-21 11:06:16 HD Request # 2 | Total records received: 121976 | 2014-08-21 11:06:16 HD Request # 2 | Requesting historical Tick data for ZN.20140900.CME_F from 2014-08-23 00:00:00 to 2014-08-23 00:00:00 (US Central Time). | 2014-08-21 11:06:16 HD Request # 2 | Received 121976 records from 2014-08-20 15:00:00 to 2014-08-21 11:06:05 (20.1 hours) and wrote 11745 records for ZN.20140900.CME_F | 2014-08-21 11:06:16 HD Request # 2 | Intraday download COMPLETE for ZN.20140900.CME_F. Completion time: 8s | 2014-08-21 11:06:16 Real-time Intraday chart data file updates started for ZN.20140900.CME_F | 2014-08-21 11:06:16 HD Request # 3 | Downloading Intraday chart data for ES.20140900.CME_Eq to the file ES.20140900.CME_Eq.scid. Service: cts | 2014-08-21 11:06:16 HD Request # 3 | Download start Date-Time: 2014-08-21 09:21:01.0 | 2014-08-21 11:06:16 HD Request # 3 | Requesting historical Tick data for ES.20140900.CME_Eq from 2014-08-21 00:00:00 to 2014-08-21 00:00:00 (US Central Time). | 2014-08-21 11:06:16 HD Request # 3 | Receiving Intraday data for ES.20140900.CME_Eq starting at 2014-08-20 15:00:00 | 2014-08-21 11:06:23 HD Request # 3 | Timestamp of first Intraday data file record written: 2014-08-21 09:21:06 | 2014-08-21 11:06:23 HD Request # 3 | Total records received: 203370 | 2014-08-21 11:06:23 HD Request # 3 | Requesting historical Tick data for ES.20140900.CME_Eq from 2014-08-22 00:00:00 to 2014-08-22 00:00:00 (US Central Time). | 2014-08-21 11:06:23 HD Request # 3 | Total records received: 203370 | 2014-08-21 11:06:23 HD Request # 3 | Requesting historical Tick data for ES.20140900.CME_Eq from 2014-08-23 00:00:00 to 2014-08-23 00:00:00 (US Central Time). | 2014-08-21 11:06:23 HD Request # 3 | Received 203370 records from 2014-08-20 15:00:00 to 2014-08-21 11:06:11 (20.1 hours) and wrote 24774 records for ES.20140900.CME_Eq | 2014-08-21 11:06:23 Added 13 Time and Sales records to Intraday data file for ES.20140900.CME_Eq after download. | 2014-08-21 11:06:24 HD Request # 3 | Intraday download COMPLETE for ES.20140900.CME_Eq. Completion time: 8s | 2014-08-21 11:06:24 Real-time Intraday chart data file updates started for ES.20140900.CME_Eq | 2014-08-21 11:06:24 CTS FIX Historical Data: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2014-08-21 11:08:23 CTS FIX Historical Data: Sending a Logout message. Text = Received Logout message. | 2014-08-21 11:08:23 CTS FIX Historical Data socket (284) | SSL shutdown indicates not able to send 'close notify'. | 2014-08-21 11:08:23 CTS FIX Historical Data socket (284) | SSL has been shut down. | 2014-08-21 11:08:23 CTS FIX Historical Data socket (284) | SSL object has been freed. SSL state is now disconnected. | 2014-08-21 11:08:23 CTS FIX Historical Data socket (284) | Shutdown and closed. | 2014-08-21 11:08:23 CTS FIX Historical Data: Logged out and disconnected. | 2014-08-21 11:08:24 CTS FIX Historical Data: Disconnected. | 2014-08-21 11:08:24 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GC.20140800.CME_CO.scid | 2014-08-21 11:19:38 CTS T4 FIX | Starting real-time market data updates for: GC.20140800.CME_CO. ID: 9 | 2014-08-21 11:19:39 Intraday data recording state for symbol GC.20140800.CME_CO is set to pending. | 2014-08-21 11:19:39 HD Request # 4 | Downloading Intraday chart data for GC.20140800.CME_CO to the file GC.20140800.CME_CO.scid. Service: cts | 2014-08-21 11:19:39 HD Request # 4 | Download start Date-Time: 2014-02-16 10:19:39.0 | 2014-08-21 11:19:39 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2014-08-21 11:19:39 CTS FIX Historical Data socket (0) | Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2014-08-21 11:19:39 CTS FIX Historical Data socket (668) | Connected. | 2014-08-21 11:19:39 CTS FIX Historical Data socket (668) | Starting SSL connection. | 2014-08-21 11:19:39 CTS FIX Historical Data socket (668) | SSL connection established. | 2014-08-21 11:19:39 CTS FIX Historical Data: Sending the Logon message. | 2014-08-21 11:19:40 CTS FIX Historical Data: Connected to Historical data server. | 2014-08-21 11:19:40 CTS T4 FIX | Sending security definition request for symbol GC.20140800.CME_CO | 2014-08-21 11:19:40 CTS T4 FIX | Received matching security definition for symbol GC.20140800.CME_CO. Subscribing to data. | 2014-08-21 11:19:40 CTS T4 FIX | Received matching security definition for symbol GC.20140800.CME_CO. Requesting historical data. | 2014-08-21 11:19:40 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-16 00:00:00 to 2014-02-16 00:00:00 (US Central Time). | 2014-08-21 11:19:40 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2014-08-21 11:19:40 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:40 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-17 00:00:00 to 2014-02-17 00:00:00 (US Central Time). | 2014-08-21 11:19:40 Symbol Error - GC.20140800.CME_CO is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2014-08-21 11:19:40 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-18 00:00:00 to 2014-02-18 00:00:00 (US Central Time). | 2014-08-21 11:19:41 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-19 00:00:00 to 2014-02-19 00:00:00 (US Central Time). | 2014-08-21 11:19:41 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-20 00:00:00 to 2014-02-20 00:00:00 (US Central Time). | 2014-08-21 11:19:41 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-21 00:00:00 to 2014-02-21 00:00:00 (US Central Time). | 2014-08-21 11:19:41 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-22 00:00:00 to 2014-02-22 00:00:00 (US Central Time). | 2014-08-21 11:19:41 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-23 00:00:00 to 2014-02-23 00:00:00 (US Central Time). | 2014-08-21 11:19:41 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-24 00:00:00 to 2014-02-24 00:00:00 (US Central Time). | 2014-08-21 11:19:41 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-25 00:00:00 to 2014-02-25 00:00:00 (US Central Time). | 2014-08-21 11:19:41 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-26 00:00:00 to 2014-02-26 00:00:00 (US Central Time). | 2014-08-21 11:19:41 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-27 00:00:00 to 2014-02-27 00:00:00 (US Central Time). | 2014-08-21 11:19:41 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-02-28 00:00:00 to 2014-02-28 00:00:00 (US Central Time). | 2014-08-21 11:19:41 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:41 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-01 00:00:00 to 2014-03-01 00:00:00 (US Central Time). | 2014-08-21 11:19:42 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:42 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-02 00:00:00 to 2014-03-02 00:00:00 (US Central Time). | 2014-08-21 11:19:42 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:42 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-03 00:00:00 to 2014-03-03 00:00:00 (US Central Time). | 2014-08-21 11:19:42 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:42 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-04 00:00:00 to 2014-03-04 00:00:00 (US Central Time). | 2014-08-21 11:19:42 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:42 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-05 00:00:00 to 2014-03-05 00:00:00 (US Central Time). | 2014-08-21 11:19:42 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:42 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-06 00:00:00 to 2014-03-06 00:00:00 (US Central Time). | 2014-08-21 11:19:42 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:42 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-07 00:00:00 to 2014-03-07 00:00:00 (US Central Time). | 2014-08-21 11:19:42 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:42 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-08 00:00:00 to 2014-03-08 00:00:00 (US Central Time). | 2014-08-21 11:19:42 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:42 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-09 00:00:00 to 2014-03-09 00:00:00 (US Central Time). | 2014-08-21 11:19:42 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:42 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-10 00:00:00 to 2014-03-10 00:00:00 (US Central Time). | 2014-08-21 11:19:42 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:42 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-11 00:00:00 to 2014-03-11 00:00:00 (US Central Time). | 2014-08-21 11:19:42 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-12 00:00:00 to 2014-03-12 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-13 00:00:00 to 2014-03-13 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-14 00:00:00 to 2014-03-14 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-15 00:00:00 to 2014-03-15 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-16 00:00:00 to 2014-03-16 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-17 00:00:00 to 2014-03-17 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-18 00:00:00 to 2014-03-18 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-19 00:00:00 to 2014-03-19 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-20 00:00:00 to 2014-03-20 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-21 00:00:00 to 2014-03-21 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-22 00:00:00 to 2014-03-22 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:43 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-23 00:00:00 to 2014-03-23 00:00:00 (US Central Time). | 2014-08-21 11:19:43 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-24 00:00:00 to 2014-03-24 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-25 00:00:00 to 2014-03-25 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-26 00:00:00 to 2014-03-26 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-27 00:00:00 to 2014-03-27 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-28 00:00:00 to 2014-03-28 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-29 00:00:00 to 2014-03-29 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-30 00:00:00 to 2014-03-30 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-03-31 00:00:00 to 2014-03-31 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-01 00:00:00 to 2014-04-01 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-02 00:00:00 to 2014-04-02 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-03 00:00:00 to 2014-04-03 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:44 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-04 00:00:00 to 2014-04-04 00:00:00 (US Central Time). | 2014-08-21 11:19:44 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:45 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-05 00:00:00 to 2014-04-05 00:00:00 (US Central Time). | 2014-08-21 11:19:45 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:45 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-06 00:00:00 to 2014-04-06 00:00:00 (US Central Time). | 2014-08-21 11:19:45 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:45 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-07 00:00:00 to 2014-04-07 00:00:00 (US Central Time). | 2014-08-21 11:19:45 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:45 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-08 00:00:00 to 2014-04-08 00:00:00 (US Central Time). | 2014-08-21 11:19:45 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:45 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-09 00:00:00 to 2014-04-09 00:00:00 (US Central Time). | 2014-08-21 11:19:45 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:45 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-10 00:00:00 to 2014-04-10 00:00:00 (US Central Time). | 2014-08-21 11:19:45 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:45 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-11 00:00:00 to 2014-04-11 00:00:00 (US Central Time). | 2014-08-21 11:19:45 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:45 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-12 00:00:00 to 2014-04-12 00:00:00 (US Central Time). | 2014-08-21 11:19:45 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:45 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-13 00:00:00 to 2014-04-13 00:00:00 (US Central Time). | 2014-08-21 11:19:45 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:45 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-14 00:00:00 to 2014-04-14 00:00:00 (US Central Time). | 2014-08-21 11:19:45 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:45 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-15 00:00:00 to 2014-04-15 00:00:00 (US Central Time). | 2014-08-21 11:19:45 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:46 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-16 00:00:00 to 2014-04-16 00:00:00 (US Central Time). | 2014-08-21 11:19:46 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:46 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-17 00:00:00 to 2014-04-17 00:00:00 (US Central Time). | 2014-08-21 11:19:46 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:46 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-18 00:00:00 to 2014-04-18 00:00:00 (US Central Time). | 2014-08-21 11:19:46 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:46 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-19 00:00:00 to 2014-04-19 00:00:00 (US Central Time). | 2014-08-21 11:19:46 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:46 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-20 00:00:00 to 2014-04-20 00:00:00 (US Central Time). | 2014-08-21 11:19:46 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:46 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-21 00:00:00 to 2014-04-21 00:00:00 (US Central Time). | 2014-08-21 11:19:46 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:46 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-22 00:00:00 to 2014-04-22 00:00:00 (US Central Time). | 2014-08-21 11:19:46 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:46 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-23 00:00:00 to 2014-04-23 00:00:00 (US Central Time). | 2014-08-21 11:19:46 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:46 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-24 00:00:00 to 2014-04-24 00:00:00 (US Central Time). | 2014-08-21 11:19:46 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:46 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-25 00:00:00 to 2014-04-25 00:00:00 (US Central Time). | 2014-08-21 11:19:46 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:46 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-26 00:00:00 to 2014-04-26 00:00:00 (US Central Time). | 2014-08-21 11:19:46 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-27 00:00:00 to 2014-04-27 00:00:00 (US Central Time). | 2014-08-21 11:19:47 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-28 00:00:00 to 2014-04-28 00:00:00 (US Central Time). | 2014-08-21 11:19:47 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-29 00:00:00 to 2014-04-29 00:00:00 (US Central Time). | 2014-08-21 11:19:47 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-04-30 00:00:00 to 2014-04-30 00:00:00 (US Central Time). | 2014-08-21 11:19:47 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-01 00:00:00 to 2014-05-01 00:00:00 (US Central Time). | 2014-08-21 11:19:47 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-02 00:00:00 to 2014-05-02 00:00:00 (US Central Time). | 2014-08-21 11:19:47 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-03 00:00:00 to 2014-05-03 00:00:00 (US Central Time). | 2014-08-21 11:19:47 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-04 00:00:00 to 2014-05-04 00:00:00 (US Central Time). | 2014-08-21 11:19:47 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-05 00:00:00 to 2014-05-05 00:00:00 (US Central Time). | 2014-08-21 11:19:47 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-06 00:00:00 to 2014-05-06 00:00:00 (US Central Time). | 2014-08-21 11:19:47 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-07 00:00:00 to 2014-05-07 00:00:00 (US Central Time). | 2014-08-21 11:19:47 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:47 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-08 00:00:00 to 2014-05-08 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:48 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-09 00:00:00 to 2014-05-09 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:48 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-10 00:00:00 to 2014-05-10 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:48 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-11 00:00:00 to 2014-05-11 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:48 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-12 00:00:00 to 2014-05-12 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:48 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-13 00:00:00 to 2014-05-13 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:48 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-14 00:00:00 to 2014-05-14 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:48 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-15 00:00:00 to 2014-05-15 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:48 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-16 00:00:00 to 2014-05-16 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:48 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-17 00:00:00 to 2014-05-17 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:48 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-18 00:00:00 to 2014-05-18 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:48 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-19 00:00:00 to 2014-05-19 00:00:00 (US Central Time). | 2014-08-21 11:19:48 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:49 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-20 00:00:00 to 2014-05-20 00:00:00 (US Central Time). | 2014-08-21 11:19:49 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:49 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-21 00:00:00 to 2014-05-21 00:00:00 (US Central Time). | 2014-08-21 11:19:49 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:49 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-22 00:00:00 to 2014-05-22 00:00:00 (US Central Time). | 2014-08-21 11:19:49 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:49 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-23 00:00:00 to 2014-05-23 00:00:00 (US Central Time). | 2014-08-21 11:19:49 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:49 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-24 00:00:00 to 2014-05-24 00:00:00 (US Central Time). | 2014-08-21 11:19:49 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:49 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-25 00:00:00 to 2014-05-25 00:00:00 (US Central Time). | 2014-08-21 11:19:49 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:49 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-26 00:00:00 to 2014-05-26 00:00:00 (US Central Time). | 2014-08-21 11:19:49 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:49 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-27 00:00:00 to 2014-05-27 00:00:00 (US Central Time). | 2014-08-21 11:19:49 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:49 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-28 00:00:00 to 2014-05-28 00:00:00 (US Central Time). | 2014-08-21 11:19:49 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:49 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-29 00:00:00 to 2014-05-29 00:00:00 (US Central Time). | 2014-08-21 11:19:49 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:49 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-30 00:00:00 to 2014-05-30 00:00:00 (US Central Time). | 2014-08-21 11:19:49 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:50 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-05-31 00:00:00 to 2014-05-31 00:00:00 (US Central Time). | 2014-08-21 11:19:50 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:50 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-01 00:00:00 to 2014-06-01 00:00:00 (US Central Time). | 2014-08-21 11:19:50 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:50 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-02 00:00:00 to 2014-06-02 00:00:00 (US Central Time). | 2014-08-21 11:19:50 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:50 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-03 00:00:00 to 2014-06-03 00:00:00 (US Central Time). | 2014-08-21 11:19:50 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:50 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-04 00:00:00 to 2014-06-04 00:00:00 (US Central Time). | 2014-08-21 11:19:50 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:50 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-05 00:00:00 to 2014-06-05 00:00:00 (US Central Time). | 2014-08-21 11:19:50 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:50 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-06 00:00:00 to 2014-06-06 00:00:00 (US Central Time). | 2014-08-21 11:19:50 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:50 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-07 00:00:00 to 2014-06-07 00:00:00 (US Central Time). | 2014-08-21 11:19:50 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:50 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-08 00:00:00 to 2014-06-08 00:00:00 (US Central Time). | 2014-08-21 11:19:50 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:50 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-09 00:00:00 to 2014-06-09 00:00:00 (US Central Time). | 2014-08-21 11:19:50 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:50 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-10 00:00:00 to 2014-06-10 00:00:00 (US Central Time). | 2014-08-21 11:19:50 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:51 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-11 00:00:00 to 2014-06-11 00:00:00 (US Central Time). | 2014-08-21 11:19:51 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:51 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-12 00:00:00 to 2014-06-12 00:00:00 (US Central Time). | 2014-08-21 11:19:51 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:51 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-13 00:00:00 to 2014-06-13 00:00:00 (US Central Time). | 2014-08-21 11:19:51 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:51 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-14 00:00:00 to 2014-06-14 00:00:00 (US Central Time). | 2014-08-21 11:19:51 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:51 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-15 00:00:00 to 2014-06-15 00:00:00 (US Central Time). | 2014-08-21 11:19:51 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:51 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-16 00:00:00 to 2014-06-16 00:00:00 (US Central Time). | 2014-08-21 11:19:51 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:51 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-17 00:00:00 to 2014-06-17 00:00:00 (US Central Time). | 2014-08-21 11:19:51 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:51 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-18 00:00:00 to 2014-06-18 00:00:00 (US Central Time). | 2014-08-21 11:19:51 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:51 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-19 00:00:00 to 2014-06-19 00:00:00 (US Central Time). | 2014-08-21 11:19:51 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:51 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-20 00:00:00 to 2014-06-20 00:00:00 (US Central Time). | 2014-08-21 11:19:51 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:51 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-21 00:00:00 to 2014-06-21 00:00:00 (US Central Time). | 2014-08-21 11:19:51 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:52 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-22 00:00:00 to 2014-06-22 00:00:00 (US Central Time). | 2014-08-21 11:19:52 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:52 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-23 00:00:00 to 2014-06-23 00:00:00 (US Central Time). | 2014-08-21 11:19:52 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:52 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-24 00:00:00 to 2014-06-24 00:00:00 (US Central Time). | 2014-08-21 11:19:52 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:52 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-25 00:00:00 to 2014-06-25 00:00:00 (US Central Time). | 2014-08-21 11:19:52 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:52 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-26 00:00:00 to 2014-06-26 00:00:00 (US Central Time). | 2014-08-21 11:19:52 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:52 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-27 00:00:00 to 2014-06-27 00:00:00 (US Central Time). | 2014-08-21 11:19:52 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:52 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-28 00:00:00 to 2014-06-28 00:00:00 (US Central Time). | 2014-08-21 11:19:52 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:52 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-29 00:00:00 to 2014-06-29 00:00:00 (US Central Time). | 2014-08-21 11:19:52 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:52 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-06-30 00:00:00 to 2014-06-30 00:00:00 (US Central Time). | 2014-08-21 11:19:52 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:52 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-01 00:00:00 to 2014-07-01 00:00:00 (US Central Time). | 2014-08-21 11:19:52 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:52 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-02 00:00:00 to 2014-07-02 00:00:00 (US Central Time). | 2014-08-21 11:19:52 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:53 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-03 00:00:00 to 2014-07-03 00:00:00 (US Central Time). | 2014-08-21 11:19:53 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:53 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-04 00:00:00 to 2014-07-04 00:00:00 (US Central Time). | 2014-08-21 11:19:53 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:53 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-05 00:00:00 to 2014-07-05 00:00:00 (US Central Time). | 2014-08-21 11:19:53 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:53 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-06 00:00:00 to 2014-07-06 00:00:00 (US Central Time). | 2014-08-21 11:19:53 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:53 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-07 00:00:00 to 2014-07-07 00:00:00 (US Central Time). | 2014-08-21 11:19:53 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:53 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-08 00:00:00 to 2014-07-08 00:00:00 (US Central Time). | 2014-08-21 11:19:53 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:53 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-09 00:00:00 to 2014-07-09 00:00:00 (US Central Time). | 2014-08-21 11:19:53 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:53 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-10 00:00:00 to 2014-07-10 00:00:00 (US Central Time). | 2014-08-21 11:19:53 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:53 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-11 00:00:00 to 2014-07-11 00:00:00 (US Central Time). | 2014-08-21 11:19:53 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:53 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-12 00:00:00 to 2014-07-12 00:00:00 (US Central Time). | 2014-08-21 11:19:53 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:53 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-13 00:00:00 to 2014-07-13 00:00:00 (US Central Time). | 2014-08-21 11:19:53 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-14 00:00:00 to 2014-07-14 00:00:00 (US Central Time). | 2014-08-21 11:19:54 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-15 00:00:00 to 2014-07-15 00:00:00 (US Central Time). | 2014-08-21 11:19:54 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-16 00:00:00 to 2014-07-16 00:00:00 (US Central Time). | 2014-08-21 11:19:54 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-17 00:00:00 to 2014-07-17 00:00:00 (US Central Time). | 2014-08-21 11:19:54 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-18 00:00:00 to 2014-07-18 00:00:00 (US Central Time). | 2014-08-21 11:19:54 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-19 00:00:00 to 2014-07-19 00:00:00 (US Central Time). | 2014-08-21 11:19:54 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-20 00:00:00 to 2014-07-20 00:00:00 (US Central Time). | 2014-08-21 11:19:54 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-21 00:00:00 to 2014-07-21 00:00:00 (US Central Time). | 2014-08-21 11:19:54 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-22 00:00:00 to 2014-07-22 00:00:00 (US Central Time). | 2014-08-21 11:19:54 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-23 00:00:00 to 2014-07-23 00:00:00 (US Central Time). | 2014-08-21 11:19:54 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-24 00:00:00 to 2014-07-24 00:00:00 (US Central Time). | 2014-08-21 11:19:54 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:54 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-25 00:00:00 to 2014-07-25 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:55 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-26 00:00:00 to 2014-07-26 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:55 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-27 00:00:00 to 2014-07-27 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:55 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-28 00:00:00 to 2014-07-28 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:55 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-29 00:00:00 to 2014-07-29 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:55 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-30 00:00:00 to 2014-07-30 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:55 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-07-31 00:00:00 to 2014-07-31 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:55 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-01 00:00:00 to 2014-08-01 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:55 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-02 00:00:00 to 2014-08-02 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:55 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-03 00:00:00 to 2014-08-03 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:55 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-04 00:00:00 to 2014-08-04 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:55 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-05 00:00:00 to 2014-08-05 00:00:00 (US Central Time). | 2014-08-21 11:19:55 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:56 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-06 00:00:00 to 2014-08-06 00:00:00 (US Central Time). | 2014-08-21 11:19:56 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:56 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-07 00:00:00 to 2014-08-07 00:00:00 (US Central Time). | 2014-08-21 11:19:56 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:56 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-08 00:00:00 to 2014-08-08 00:00:00 (US Central Time). | 2014-08-21 11:19:56 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:56 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-09 00:00:00 to 2014-08-09 00:00:00 (US Central Time). | 2014-08-21 11:19:56 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:56 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-10 00:00:00 to 2014-08-10 00:00:00 (US Central Time). | 2014-08-21 11:19:56 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:56 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-11 00:00:00 to 2014-08-11 00:00:00 (US Central Time). | 2014-08-21 11:19:56 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:56 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-12 00:00:00 to 2014-08-12 00:00:00 (US Central Time). | 2014-08-21 11:19:56 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:56 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-13 00:00:00 to 2014-08-13 00:00:00 (US Central Time). | 2014-08-21 11:19:56 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:56 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-14 00:00:00 to 2014-08-14 00:00:00 (US Central Time). | 2014-08-21 11:19:56 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:56 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-15 00:00:00 to 2014-08-15 00:00:00 (US Central Time). | 2014-08-21 11:19:56 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:56 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-16 00:00:00 to 2014-08-16 00:00:00 (US Central Time). | 2014-08-21 11:19:56 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:57 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-17 00:00:00 to 2014-08-17 00:00:00 (US Central Time). | 2014-08-21 11:19:57 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:57 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-18 00:00:00 to 2014-08-18 00:00:00 (US Central Time). | 2014-08-21 11:19:57 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:57 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-19 00:00:00 to 2014-08-19 00:00:00 (US Central Time). | 2014-08-21 11:19:57 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:57 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-20 00:00:00 to 2014-08-20 00:00:00 (US Central Time). | 2014-08-21 11:19:57 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:57 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-21 00:00:00 to 2014-08-21 00:00:00 (US Central Time). | 2014-08-21 11:19:57 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:57 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-22 00:00:00 to 2014-08-22 00:00:00 (US Central Time). | 2014-08-21 11:19:57 HD Request # 4 | Total records received: 0 | 2014-08-21 11:19:57 HD Request # 4 | Requesting historical Tick data for GC.20140800.CME_CO from 2014-08-23 00:00:00 to 2014-08-23 00:00:00 (US Central Time). | 2014-08-21 11:19:57 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GC.20140800.CME_CO | 2014-08-21 11:19:57 HD Request # 4 | Intraday download COMPLETE for GC.20140800.CME_CO. Completion time: 18s | 2014-08-21 11:19:57 Real-time Intraday chart data file updates started for GC.20140800.CME_CO | 2014-08-21 11:19:57 |
| [2014-08-21 18:34:06] |
This is the problem: Symbol Error - GC.20140800.CME_CO is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2014-08-21 11:19:40
You will need to contact your broker about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
