Date/Time: Sun, 24 Nov 2024 09:34:02 +0000
[Programming Help] - DOM Center-line not working
View Count: 183
[2024-06-07 02:45:51] |
user230598 - Posts: 1 |
Hi, I found that when using the DOM occasionally the center-line will be located a tick below where it should. I have only found this problem on euro schatz and bund futures (currently september/U contract), as I use the exact same DOM/Studies/settings on multiple other products (including other euro bond futures) and it is only these two products that I have found affected. In the screenshot, on the Bund/3rd DOM from left that the highlight of last traded price, circled in green, is lagging behind the current print/market order, which could have an affect. It does not seem to be the result of the custom study for the price column, as I have tested this with and without the study, as well as having this study active on other DOMs without issue. Is there a setting that I have accidentally changed somewhere that causes this? Or is this a bug that can be fixed when time permits? Thank you! |
Attachment Deleted. Screenshot 2024-06-07 121803.png / V - Attached On 2024-06-07 02:29:36 UTC - Size: 207.01 KB - 42 views |
[2024-06-07 21:57:53] |
Sierra_Chart Engineering - Posts: 17154 |
This is going to be random how this works. If you are referring to the middle line, it is calculated to be in the middle but then it is rounded off so that it does not intersect a price.
