Date/Time: Sun, 24 Nov 2024 09:36:09 +0000
file downloads enabled
View Count: 180
[2024-06-07 00:21:48]
User204705 - Posts: 4
I want to see if I have custom files set to download on startup , but I cant find this option Can you please tell me where I can find this?.
[2024-06-07 14:19:44]
Within your Sierra Chart software select "Help >> Account Control Panel". This will open a browser and take you to your Account Control Panel on our website. On that page select the menu near the top for "Account Panel >> Enabled Studies and Files Set to Download".
Near the top is an option to "Disable File Downloads" and also shows the current status of whether this is Enabled or Disabled.
Towards the bottom of the page is the list of files that would be downloaded.
