Date/Time: Sun, 27 Sep 2026 01:29:21 +0000
switch between DAY and GTC
View Count: 1751
| [2014-08-21 15:00:37] |
| User93731 - Posts: 84 |
Hi: My broker Rithmic did not take GTC (good until cancelled) type of order. Even I had switched to DAY at SC, I still received the LOG message saying my orders are rejected and "operation not supported". Rithmic told me that it was due to the order being submitted as GTC (even I has made them as DAY). Please help. Thanks. |
| [2014-08-21 16:10:49] |
There are two Time in Force settings on the Trade Window. One on the Main tab and another one on the Targets tab. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TIF Attached Orders: Time In Force Check them both. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
