Date/Time: Sun, 24 Nov 2024 09:23:29 +0000
Profit and Loss Format Issue
View Count: 187
[2024-06-06 21:29:09]
hamboz - Posts: 16
I made $495 today which is 99 ticks and 24.75 points but my trade window shows 99T and when I go the settings and change it to points, it still shows 99P instead of 24.75P, why is this happening? I attached my trade window
imageProfit and Loss Issue 1.PNG / V - Attached On 2024-06-06 21:28:53 UTC - Size: 180.39 KB - 47 views
imageProfit and Loss Issue 2.PNG / V - Attached On 2024-06-06 21:28:59 UTC - Size: 169.24 KB - 38 views
[2024-06-06 21:34:52]
What is the Tick Size of that chart set to (Chart >> Chart Settings >> Symbol >> Tick Size)?
[2024-06-06 21:53:02]
hamboz - Posts: 16
Tick Size is set to 1
[2024-06-07 14:11:09]
Your Tick Size is not the actual tick size used by the exchange. NQ has a Tick Size of 0.25, so the calculation for the number of points is not being done correctly. You would need to change your tick size back to 0.25 in order to get the Points correct.
