Date/Time: Sun, 24 Nov 2024 11:57:40 +0000
[User Discussion] - Linux / Mint Weird Menu Behavior
View Count: 195
[2024-06-06 15:43:14] |
Tony - Posts: 516 |
Hi, I running Sierra on Linux Mint and Wine 7, everything was normal until a few weeks ago the menus started this weird behavior. I have a external monitor set up as it shows in attachment Monitor.png, when I run Sierra in the Main Monitor, the menu looks normal as it shows in attachment Expected.png, but when I move Sierra window to the External Monitor and maximize the window, the menu always detached to the menu bar, as it shows in Weird.png (it seems that top of the menu aligned with the top of Main Monitor) Not sure if there is a way to fix this Thanks a lot! |
Monitors.png / V - Attached On 2024-06-06 15:40:56 UTC - Size: 15.73 KB - 44 views Expected.jpg / V - Attached On 2024-06-06 15:41:03 UTC - Size: 109.11 KB - 55 views |
[2024-06-06 18:48:54] |
ertrader - Posts: 672 |
Odd.. have not seen that issue. I'm on Mint Linux 21.3 but use a much newer wine version and do use OpenGL. Here is my latest setup. Linux Date Time Of Last Edit: 2024-06-06 18:49:37
[2024-06-06 18:56:13] |
Tony - Posts: 516 |
Thanks ertrader! I probably will have to install new Mint with kernel 6, I am still using kernel 5 and getting the message on the taskbar that Mint will stop supporting by August this year
Date Time Of Last Edit: 2024-06-06 18:56:39
