Date/Time: Thu, 19 Sep 2024 21:34:33 +0000
auto snap
View Count: 1868
[2014-08-21 14:01:42] |
User120827 - Posts: 77 |
Is there any way to disable snap feature on cursor ? regards |
[2014-08-21 16:34:47] |
Refer to the documentation here about Chart Drawing snapping: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Snapping Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
