Date/Time: Sun, 24 Nov 2024 08:50:05 +0000
Message Log Window does not stay detached
View Count: 240
[2024-06-06 05:18:48] |
Benutzer4711 - Posts: 35 |
Hello, I have a problem with the detached message log window. I detach multiple windows - Message Log - Trade Service Log - Trade Orders - Trade Position to move them on a separate screen. And see each of those as a separate tab on the Windows Task Bar. Out of these 4 the Message Log window is not staying "detached" after shut down & restart of SC. After I start SC, all Windows except Message Log load and are detached. Message Log window appears and is visible on top of all loaded chart windows/chartbooks, but not detached. I have to click in the Message Log Window --> Edit --> Attach/Detach Log *twice* to detach it and make visible in the Task Bar. Since i have to click it twice, this indicates that the window is "attaching" and then "detaching". I remember that this was not the case in an older Sierra Chart Version. I did a test with fresh installs: Downloaded 2296 --> Message Log window does stay detached ! That's how it should be... Updated 2296 to current version 2644 --> Message Log window does not stay detached Downloaded current 2644 --> Message Log window does not stay detached So there must have been a change in the updates causing this. Any idea? |
[2024-06-06 22:23:30] |
Sierra_Chart Engineering - Posts: 17154 |
This will be corrected in the next release.
[2024-06-07 07:48:38] |
Thank You !!
[2024-06-10 19:41:23] |
Update to the latest prerelease to resolve this. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-11 04:21:28] |
Perfect. Prerelease 2645 has resolved the issue. Good Job! |
