Date/Time: Fri, 20 Sep 2024 00:39:25 +0000
DateTime to Index
View Count: 2332
[2014-08-21 13:46:06] |
AC94882 - Posts: 8 |
Hi, How can i get the current bar index of the chart by giving the datetime? How can i get the OHLC values by giving the datetime? Ariel |
[2014-08-21 16:35:51] |
Are you referring to the Advanced Custom Study Interface and Language?
[2014-08-21 16:59:20] |
Yes, How to get the data with ACSIL Thanks. |
[2014-08-22 01:10:28] |
vegasfoster - Posts: 444 |
You can see here http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetNearestMatchForSCDateTime and here http://www.sierrachart.com/index.php?page=doc/doc_SCDateTime.html An example would be if you wanted daily open then could do something like, SCSubgraphRef DailyOpen = sc.Subgraph[0]; SCSubgraphRef ReferenceIndex = sc.Subgraph[10]; if (sc.SetDefaults) { sc.GraphName = "Daily Open"; sc.AutoLoop = true; DailyOpen.Name = "Daily Open"; DailyOpen.LineWidth = 1; sc.Input[0].Name = "Hour"; sc.Input[0].SetInt(9); sc.Input[1].Name = "Minute"; sc.Input[1].SetInt(30); return; } int Year = sc.BaseDateTimeIn[sc.Index].GetYear(); int Month = sc.BaseDateTimeIn[sc.Index].GetMonth(); int Day = sc.BaseDateTimeIn[sc.Index].GetDay(); SCDateTime DateTime(Year, Month, Day, sc.Input[0].GetInt(), sc.Input[1].GetInt(), 0); int InputIndex = sc.GetNearestMatchForSCDateTime(sc.ChartNumber, DateTime); ReferenceIndex[sc.Index] = sc.BaseDateTimeIn[sc.Index-1] < DateTime && sc.BaseDateTimeIn[sc.Index] >= DateTime ? InputIndex : ReferenceIndex[sc.Index-1]; DailyOpen[sc.Index] = sc.Open[ReferenceIndex[sc.Index]]; Date Time Of Last Edit: 2014-08-22 01:11:39
[2014-09-03 05:56:18] |
In response to the first post, these are the relevant functions: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetNearestMatchForSCDateTime http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetOHLCForDate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
