Date/Time: Sun, 24 Nov 2024 12:02:17 +0000
rithmic connection problem after all updates was performed and broker was contacted too
View Count: 179
[2024-06-05 22:29:15] |
lovelivelaught - Posts: 49 |
Hello I installed your latest software version. Performed manual entry to data service connection. I contacted a broker for a Rithmic connection problem and they have no idea what the problem could be. They contacted Rithmic as well directely and Rithmic said that they are not reporting any issues or outrageges. . The error is "permission denied" is still here. Everytime I disconnected and connected to the server the charts got updated to current time. it looked like that there is some kind of connection there. Please check it out. 2024-06-05 16:10:30.419 | Software version: 2643 64-bit 2024-06-05 16:10:30.419 | Primary Thread ID: 15976 2024-06-05 16:10:30.419 | Usage end date: 2024-09-16 2024-06-05 16:10:30.419 | Enabled for: Advanced Features 2. 2024-06-05 16:10:30.419 | Enabled for: Sierra Chart Historical Data Service. 2024-06-05 16:10:30.419 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-06-05 16:10:30.419 | Enabled for: Delayed Denali Exchange Data Feed. 2024-06-05 16:10:30.419 | Enabled for exchange2: CME 2024-06-05 16:10:30.419 | Enabled for exchange2: US Equities Consolidated Tape 2024-06-05 16:10:30.419 | Enabled for exchange2: NASDAQ Global Indexes 2024-06-05 16:10:30.419 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-06-05 16:10:30.419 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-06-05 16:10:30.419 | Custom symbol settings values: enabled 2024-06-05 16:10:30.419 | Chart Update Interval: 1000 2024-06-05 16:10:30.419 | Intraday Data Storage Time Unit: 0 2024-06-05 16:10:30.419 | Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) 2024-06-05 16:10:30.419 | 2024-06-05 22:10:30 Local computer time in UTC 2024-06-05 16:10:30.419 | 2024-06-05 16:10:30 Local computer time in SC Time Zone 2024-06-05 16:10:30.419 | 2024-06-05 13:02:15 Server time in UTC 2024-06-05 16:10:30.420 | Local computer UTC time and Server UTC time difference: 0 seconds. 2024-06-05 16:10:30.420 | Program path: D:\SierraChart\ 2024-06-05 16:10:30.420 | Data Files path: D:\SierraChart\Data\ 2024-06-05 16:10:30.420 | OS Version Number: 10.0 2024-06-05 16:10:30.420 | Locale Setting: C 2024-06-05 16:10:30.420 | DLLs: UserContributedStudies_64.dll 2024-06-05 16:10:30.420 | Allowed protected custom studies: zyp_download_free 2024-06-05 16:10:30.420 | Crash reporter started: true 2024-06-05 16:10:30.420 | 2024-06-05 16:10:42.317 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:10:42.317 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | New receive buffer size: 0 2024-06-05 16:10:42.317 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | Connecting to IP: 38.79.0.89. 2024-06-05 16:10:42.892 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2024-06-05 16:10:42.893 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | CloseSocket call. 2024-06-05 16:10:42.893 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-06-05 16:10:42.893 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (1) | Closed. 2024-06-05 16:12:22.556 | 2024-06-05 16:12:22.557 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:12:22.557 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:12:22.561 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:12:22.561 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:12:22.561 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:12:22.615 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:12:22.615 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:12:22.615 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:12:22.615 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:12:22.786 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:12:22.786 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:12:22.786 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:12:22.787 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:12:22.787 | Rithmic Direct - DTC | Failed connections: 59 2024-06-05 16:12:22.787 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:12:22.787 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:12:22.803 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:12:22.804 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:12:22.804 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:12:22.804 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:12:22.805 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:12:22.856 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:12:22.856 | DTC Client socket (1) | Closed. 2024-06-05 16:12:42.667 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:12:42.667 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | New receive buffer size: 0 2024-06-05 16:12:42.667 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | Connecting to IP: 38.79.0.89. 2024-06-05 16:12:43.235 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | Socket gracefully closed by remote side. | Number times message added: 1 2024-06-05 16:12:43.238 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | CloseSocket call. 2024-06-05 16:12:43.238 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-06-05 16:12:43.238 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (1) | Closed. 2024-06-05 16:13:25.104 | File >> Disconnect selected. 2024-06-05 16:13:25.104 | DTC Client socket (0) | CloseSocket call. 2024-06-05 16:13:25.104 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:13:31.140 | 2024-06-05 16:13:31.142 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:13:31.142 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:13:31.162 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:13:31.162 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:13:31.162 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:13:31.217 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:13:31.217 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:13:31.217 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:13:31.217 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:13:31.386 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:13:31.386 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:13:31.386 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:13:31.386 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:13:31.386 | Rithmic Direct - DTC | Failed connections: 60 2024-06-05 16:13:31.386 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:13:31.386 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:31.395 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:13:31.397 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:13:31.397 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:13:31.397 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:13:31.397 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:31.448 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:13:31.448 | DTC Client socket (1) | Closed. 2024-06-05 16:13:35.395 | 2024-06-05 16:13:35.397 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:13:35.397 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:13:35.398 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:13:35.398 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:13:35.398 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:13:35.451 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:13:35.451 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:13:35.451 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:13:35.451 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:13:35.621 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:13:35.621 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:13:35.621 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:13:35.621 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:13:35.621 | Rithmic Direct - DTC | Failed connections: 61 2024-06-05 16:13:35.621 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:13:35.621 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:35.629 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:13:35.629 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:13:35.630 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:13:35.630 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:35.630 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:13:35.682 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:13:35.682 | DTC Client socket (1) | Closed. 2024-06-05 16:13:39.635 | 2024-06-05 16:13:39.635 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:13:39.635 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:13:39.636 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:13:39.636 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:13:39.636 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:13:39.688 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:13:39.688 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:13:39.688 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:13:39.688 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:13:39.854 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:13:39.854 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:13:39.854 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:13:39.854 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:13:39.854 | Rithmic Direct - DTC | Failed connections: 62 2024-06-05 16:13:39.854 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:13:39.854 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:39.895 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:13:39.896 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:13:39.896 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:13:39.896 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:39.897 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:13:39.949 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:13:39.949 | DTC Client socket (1) | Closed. 2024-06-05 16:13:43.902 | 2024-06-05 16:13:43.902 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:13:43.902 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:13:43.903 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:13:43.903 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:13:43.903 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:13:43.956 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:13:43.956 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:13:43.956 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:13:43.956 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:13:44.127 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:13:44.127 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:13:44.127 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:13:44.127 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:13:44.127 | Rithmic Direct - DTC | Failed connections: 63 2024-06-05 16:13:44.127 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:13:44.127 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:44.148 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:13:44.149 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:13:44.150 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:13:44.150 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:13:44.150 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:44.202 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:13:44.202 | DTC Client socket (1) | Closed. 2024-06-05 16:13:48.144 | 2024-06-05 16:13:48.145 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:13:48.145 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:13:48.157 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:13:48.157 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:13:48.157 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:13:48.211 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:13:48.211 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:13:48.211 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:13:48.211 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:13:48.380 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:13:48.380 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:13:48.380 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:13:48.380 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:13:48.380 | Rithmic Direct - DTC | Failed connections: 64 2024-06-05 16:13:48.380 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:13:48.380 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:48.395 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:13:48.395 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:13:48.395 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:13:48.395 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:48.395 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:13:48.446 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:13:48.447 | DTC Client socket (1) | Closed. 2024-06-05 16:13:52.398 | 2024-06-05 16:13:52.398 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:13:52.398 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:13:52.400 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:13:52.400 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:13:52.400 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:13:52.452 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:13:52.452 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:13:52.452 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:13:52.452 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:13:52.623 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:13:52.623 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:13:52.623 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:13:52.623 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:13:52.623 | Rithmic Direct - DTC | Failed connections: 65 2024-06-05 16:13:52.623 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:13:52.623 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:52.627 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:13:52.627 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:13:52.628 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:13:52.628 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:13:52.628 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:52.680 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:13:52.680 | DTC Client socket (1) | Closed. 2024-06-05 16:13:56.648 | 2024-06-05 16:13:56.648 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:13:56.648 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:13:56.648 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:13:56.648 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:13:56.648 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:13:56.700 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:13:56.700 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:13:56.700 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:13:56.700 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:13:56.874 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:13:56.874 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:13:56.874 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:13:56.874 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:13:56.874 | Rithmic Direct - DTC | Failed connections: 66 2024-06-05 16:13:56.874 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:13:56.874 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:56.892 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:13:56.893 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:13:56.893 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:13:56.893 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:13:56.893 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:13:56.945 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:13:56.945 | DTC Client socket (1) | Closed. 2024-06-05 16:14:00.894 | 2024-06-05 16:14:00.894 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:00.894 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:00.895 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:00.895 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:00.895 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:00.948 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:00.948 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:00.948 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:00.948 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:01.120 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:01.120 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:01.120 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:01.120 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:01.120 | Rithmic Direct - DTC | Failed connections: 67 2024-06-05 16:14:01.120 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:01.120 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:01.131 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:01.132 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:01.132 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:01.132 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:01.132 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:01.184 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:01.184 | DTC Client socket (1) | Closed. 2024-06-05 16:14:05.134 | 2024-06-05 16:14:05.134 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:05.134 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:05.148 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:05.148 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:05.148 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:05.205 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:05.205 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:05.205 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:05.205 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:05.378 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:05.378 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:05.378 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:05.378 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:05.378 | Rithmic Direct - DTC | Failed connections: 68 2024-06-05 16:14:05.378 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:05.378 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:05.394 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:05.395 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:05.395 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:05.395 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:05.395 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:05.447 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:05.447 | DTC Client socket (1) | Closed. 2024-06-05 16:14:09.411 | 2024-06-05 16:14:09.412 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:09.412 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:09.412 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:09.412 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:09.412 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:09.463 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:09.463 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:09.463 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:09.463 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:09.637 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:09.637 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:09.637 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:09.637 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:09.637 | Rithmic Direct - DTC | Failed connections: 69 2024-06-05 16:14:09.637 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:09.637 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:09.645 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:09.646 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:09.646 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:09.646 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:09.646 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:09.697 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:09.697 | DTC Client socket (1) | Closed. 2024-06-05 16:14:13.645 | 2024-06-05 16:14:13.645 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:13.645 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:13.645 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:13.645 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:13.645 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:13.697 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:13.697 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:13.697 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:13.697 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:13.876 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:13.876 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:13.876 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:13.876 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:13.876 | Rithmic Direct - DTC | Failed connections: 70 2024-06-05 16:14:13.876 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:13.876 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:13.892 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:13.893 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:13.893 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:13.893 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:13.893 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:13.945 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:13.945 | DTC Client socket (1) | Closed. 2024-06-05 16:14:17.907 | 2024-06-05 16:14:17.907 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:17.907 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:17.908 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:17.908 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:17.908 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:17.960 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:17.960 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:17.960 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:17.960 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:18.131 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:18.131 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:18.131 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:18.131 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:18.131 | Rithmic Direct - DTC | Failed connections: 71 2024-06-05 16:14:18.131 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:18.131 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:18.144 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:18.145 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:18.145 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:18.145 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:18.145 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:18.198 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:18.198 | DTC Client socket (1) | Closed. 2024-06-05 16:14:22.149 | 2024-06-05 16:14:22.150 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:22.150 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:22.154 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:22.154 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:22.154 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:22.207 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:22.207 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:22.207 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:22.207 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:22.373 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:22.373 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:22.373 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:22.373 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:22.373 | Rithmic Direct - DTC | Failed connections: 72 2024-06-05 16:14:22.373 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:22.373 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:22.382 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:22.382 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:22.382 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:22.382 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:22.382 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:22.437 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:22.437 | DTC Client socket (1) | Closed. 2024-06-05 16:14:26.386 | 2024-06-05 16:14:26.386 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:26.386 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:26.386 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:26.386 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:26.386 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:26.440 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:26.440 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:26.440 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:26.440 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:26.604 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:26.604 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:26.604 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:26.604 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:26.604 | Rithmic Direct - DTC | Failed connections: 73 2024-06-05 16:14:26.604 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:26.604 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:26.610 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:26.611 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:26.611 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:26.611 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:26.611 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:26.663 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:26.663 | DTC Client socket (1) | Closed. 2024-06-05 16:14:30.664 | 2024-06-05 16:14:30.664 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:30.664 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:30.664 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:30.665 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:30.665 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:30.717 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:30.717 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:30.717 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:30.717 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:30.883 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:30.883 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:30.883 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:30.883 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:30.883 | Rithmic Direct - DTC | Failed connections: 74 2024-06-05 16:14:30.883 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:30.883 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:30.893 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:30.893 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:30.894 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:30.894 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:30.894 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:30.945 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:30.945 | DTC Client socket (1) | Closed. 2024-06-05 16:14:34.899 | 2024-06-05 16:14:34.900 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:34.900 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:34.901 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:34.901 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:34.901 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:34.952 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:34.952 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:34.953 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:34.953 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:35.123 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:35.123 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:35.123 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:35.123 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:35.123 | Rithmic Direct - DTC | Failed connections: 75 2024-06-05 16:14:35.123 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:35.123 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:35.134 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:35.135 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:35.135 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:35.135 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:35.135 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:35.186 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:35.186 | DTC Client socket (1) | Closed. 2024-06-05 16:14:39.134 | 2024-06-05 16:14:39.134 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:39.134 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:39.152 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:39.152 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:39.152 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:39.209 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:39.209 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:39.209 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:39.209 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:39.385 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:39.385 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:39.385 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:39.385 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:39.385 | Rithmic Direct - DTC | Failed connections: 76 2024-06-05 16:14:39.385 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:39.385 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:39.395 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:39.396 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:39.396 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:39.396 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:39.396 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:39.454 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:39.454 | DTC Client socket (1) | Closed. 2024-06-05 16:14:43.411 | 2024-06-05 16:14:43.412 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:43.412 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:43.413 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:43.413 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:43.413 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:43.466 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:43.466 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:43.466 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:43.466 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:43.645 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:43.645 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:43.645 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:43.645 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:43.645 | Rithmic Direct - DTC | Failed connections: 77 2024-06-05 16:14:43.645 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:43.645 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:43.664 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:43.665 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:43.665 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:43.665 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:43.665 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:43.716 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:43.716 | DTC Client socket (1) | Closed. 2024-06-05 16:14:47.669 | 2024-06-05 16:14:47.669 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2024-06-05 16:14:47.669 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2024-06-05 16:14:47.669 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-06-05 16:14:47.670 | DTC Client socket (1) | New receive buffer size: 0 2024-06-05 16:14:47.670 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-06-05 16:14:47.721 | Rithmic Direct - DTC | Network connection to server complete. 2024-06-05 16:14:47.721 | Rithmic Direct - DTC | Starting socket receive thread. 2024-06-05 16:14:47.721 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-06-05 16:14:47.721 | Rithmic Direct - DTC | Sending logon request message. 2024-06-05 16:14:47.891 | Rithmic Direct - DTC | Received logon response. 2024-06-05 16:14:47.891 | Rithmic Direct - DTC | Server Name: . 2024-06-05 16:14:47.891 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-06-05 16:14:47.891 | Rithmic Direct - DTC | Logon error received from server: permission denied 2024-06-05 16:14:47.891 | Rithmic Direct - DTC | Failed connections: 78 2024-06-05 16:14:47.891 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-06-05 16:14:47.891 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:47.910 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-06-05 16:14:47.910 | DTC Client socket (1) | CloseSocket call. 2024-06-05 16:14:47.910 | Rithmic Direct - DTC | Disconnected. 2024-06-05 16:14:47.910 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-06-05 16:14:47.911 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-06-05 16:14:47.963 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-06-05 16:14:47.963 | DTC Client socket (1) | Closed. |
[2024-06-06 12:20:18] |
Sierra_Chart Engineering - Posts: 17154 |
We cannot help with the "permission denied" error beyond the information here: Rithmic Trading Platform Service: Permission Denied Resolution Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
