Date/Time: Sun, 24 Nov 2024 11:36:40 +0000
Delayed data and No TPO Profile
View Count: 175
[2024-06-05 21:04:47]
User492625 - Posts: 1
I have purchased package 10 and US Consolidated Equities tape live data and on the platform it says my data is delayed and that my service package doesnt support this function. How do I fix this?
[2024-06-05 21:40:36]
You should not have delayed data for the U.S. Equities Consolidated Tape. You have the exchange properly activated. Make sure you are entering the symbols for the charts as the standard symbol (i.e. IBM, or TSLA). Do not add any modifiers. This will give you the data from the U.S. Equities Combined Tape.
As to the TPO charts, the issue there is that you are on the "Integrated Standard" package. The TPO charts are only available with the "Advanced" packages, so you will need to change our package. Refer to the information on the packages at the following link:
Description of Service Packages and Pricing: Integrated Packages
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
