Date/Time: Sun, 24 Nov 2024 11:55:06 +0000
Linking unlinked existing orders, is it possible?
View Count: 146
[2024-06-05 19:53:47] |
John M - Posts: 171 |
I have an existing limit sale and a sell stop order but they are not linked, ie, OCO Is there a way to establish an OCO relationship between the two where it does not presently exist ? thanks! |
[2024-06-05 20:16:49] |
You can not link the existing orders. You would need to remove them and then send a new set of orders using the "Send Attached Orders By Position/Price". Refer to the following: Order Types: Send Attached Orders - Position/Price For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
