Date/Time: Sun, 24 Nov 2024 11:55:37 +0000
Reloading charts
View Count: 145
[2024-06-05 19:27:26] |
User674409 - Posts: 24 |
Why from time to time, when I recenter my Dom with the "R" hotkey, Sierra chart reload all my charts? Obviously this takes a lot of time, and it happened to me that I missed a trade, because at that moment, SC started reloading the charts and I couldnt see what was happening.
[2024-06-05 19:48:54] |
We do not know. There is no reason for the charts to reload when recentering the DOMs. The one thing we want to point out, however, is that you should not use a single keystroke (such as 'R') for a keyboard shortcut. You should always us a modifier key with it (such as 'Ctrl-R', or 'Alt-R'), as this helps to ensure that the R key by itself is not interpreted as something else. For instance, you can quickly change the bar period of a chart by selecting a specific series of keystrokes. One option is to enter a number followed by R and then Enter to change to a Range chart (for instance if you select '5-r-enter' you will get a 5 tick range chart). We wonder if it is something along these lines that is causing you the issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
