Date/Time: Sun, 24 Nov 2024 09:01:28 +0000
Attached Orders & Order Allocation
View Count: 300
[2024-06-05 19:19:56] |
User749040 - Posts: 37 |
Hello SC team I have a question about the Attached Orders and Order Allocation. 1. When using Attached Orders with 2 targets, the loss presented in points is based on 1 contract, not the whole OCO Group even tho it's set as an OCO Group. (Screenshot attached)) When using 1 stop and 1 target then the loss gets calculated on both contracts which I prefer. Is there a way to set the second example on multiple OCOs? Otherwise I'd have to calculate the loss * contract all the time. https://www.sierrachart.com/image.php?Image=1717614964621.png https://www.sierrachart.com/image.php?Image=171761502392.png 2. When using Order Allocation and I have 10 accounts linked together, can I have different Attached Orders on some accounts? Example: 5 accounts being traded with 2 targets 1 stop and 5 accounts being traded with 1 target 1 stop? Thank you. **Edit** I forgot to add that I have enabled Scale In/Scale Out Date Time Of Last Edit: 2024-06-05 19:33:59
[2024-06-05 21:55:09] |
Sierra_Chart Engineering - Posts: 17154 |
1. You will only see the loss amount for the order that is shown on top of the other orders since the Stop order is split up into multiple orders due to multiple OCO groups. 2. No there is definitely no support for something like this at all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-06 14:54:46] |
1. Yes, I'm aware that all stops are at the same place based on how many OCO Groups you have. So in the first screenshot, 2 OCO groups for a target and that's why the Stop has -3P when in reality if it gets hit I'm losing 6P. Is there a way to always show the amount of all the stops together no matter how many targets you have like on the second screenshot? 2. Understandable. Thank you. |
[2024-06-06 20:46:30] |
1. No, there is no support for this. Unless we could use the total quantity somehow. We will have a quick look at that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-06 20:47:19
[2024-06-06 21:53:46] |
We will implement a solution to consider total quantity of multiple stop orders on top of each other, for PL calculations, in the next release.
[2024-06-06 22:06:13] |
Thank you very much, could you let me know when that update is out so I can update?
[2024-06-10 19:49:11] |
This is now out. It is the latest prerelease.
[2024-06-10 21:24:38] |
Works like a charm, thank you for the fast implementation.
