Date/Time: Sun, 24 Nov 2024 10:33:25 +0000
SP11 and Level 2 real time data
View Count: 153
[2024-06-05 15:20:33] |
moneyboy888 - Posts: 25 |
Hi, I've upgraded from Level 1 back to Level 2 data with SP11. I still do not see the market depth/10 price levels reflected in the DOM chart yet? How long will it take the system to update? It's been almost an hour already. Thanks. Rgds., |
[2024-06-05 15:41:09] |
The change would be immediate. Just in case, select "File >> Reconnect". If you continue to have an issue, then what is one symbol for which you are having a problem? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
