Date/Time: Sun, 24 Nov 2024 11:01:47 +0000
send chartbook
View Count: 165
[2024-06-05 14:30:37] |
User596209 - Posts: 12 |
how do I send a chartbook to another sierra chart user
[2024-06-05 15:33:39] |
Refer to the following: File Menu: Send File to User (File) You can also copy it to them or send via email. Refer to the following: Chartbooks (Workspaces): Sharing a Chartbook with Another User or Copying it to Another Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
