Date/Time: Sun, 24 Nov 2024 11:14:23 +0000
Control Bar Ability
View Count: 177
[2024-06-05 12:22:56]
User749040 - Posts: 37
Hello SC team, I have two questions.
1. Is it possible to add a button in the control bar to add/remove a study/study collection. I know there is a way to add a study through a button but that just adds it and I need to manually go in the Studies and remove it. If I click the button again it just adds the study again. Or if that's not possible is there a way to hide/unhide a certain study/study collection.
2. Is it possible to have a button to hide/unhide drawings from chart. Looking for a better way to group drawings, either like a folder which I can hide/unhide or just a simple hide all drawings from chart option on the control bar would be very useful.
Thank you.
[2024-06-05 15:13:07]
1. You can add Study Collections through the Control Bar buttons. Refer to the following:
Control Bar: Control Bar Study Collection Buttons and Keyboard Shortcuts
There is not a way to Show/Hide specific studies with Control Bar buttons or keyboard shortcuts.
2. There is no specific support for this. The best option is to use the "Manage Chart Drawings" window and select the drawings you want to hide and then you can hide them all at once by selecting the "Hide" button. Refer to the following:
Chart Drawing Tools: Manage Chart Drawings
