Date/Time: Tue, 15 Sep 2026 05:24:11 +0000
Australian Market Data
View Count: 1930
| [2014-08-21 04:05:30] |
| User66484 - Posts: 2 |
Hi, I would really like to be able to view Australian Shares on Sierra Charts. I have an account with Infinity to trade futures an understand that they don't have Aus market capability. I have searched the site to see how or if it is possible? I found that the ASX share data is available under symbols. So what is required am I able to have another log in account or have an account with another brokerage firm? My first preference would be to have another login account as I can use a broker here in Australia. I love the charting software that Sierra have and found all the others here in Australia to second rate. Thanks you for reading this email. Andrew |
| [2014-08-21 07:01:34] |
You just need to use your own direct account which you already have and pay for Sierra Chart on that account. Here is complete information: http://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html For ASX share data, you need to use the Sierra Chart Historical Data Service: http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-21 07:01:53
| [2014-08-21 09:44:23] |
If I was to select this option below "Once you have completed the steps and now have a direct Sierra Chart account, you will no longer need your other Sierra Chart account you may have had through the affiliate. You will no longer need to pay for Sierra Chart through the affiliate if you have been doing that, and can cancel with them." Would I effectively give up the discount infinity option for their futures charting???? "Pricing Level 3 Charts - $0 per month with 10 round turns per 30 day cycle - $15.95 per month with less than 10 round turns per 30 day cycle" |
| [2014-08-21 16:04:26] |
The standard Sierra Chart pricing applies.
