Date/Time: Sun, 24 Nov 2024 07:01:16 +0000
futures spreads
View Count: 240
[2024-06-05 11:26:50] |
User181801 - Posts: 42 |
Hello and thanks for your help, I cannot see any dropdown for products in the symbol list for futures spreads, both nymex and cbot. Is it a different subscription or do I need to enable something? thanks for your advice. |
[2024-06-05 15:08:55] |
Refer to the following for how to get the list of Spreads: Denali Exchange Data Feed: Using Denali Futures Spread Data with Trading Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-16 11:29:33] |
SpearChucker - Posts: 104 |
Previously I could select spreads from CBOT, CME, NYMEX... Now only CBOT is available. Are the others not available? I use Denali data and Teton routing and have followed the instructions in your post above. Thanks.
[2024-06-17 09:26:01] |
Sierra_Chart Engineering - Posts: 17154 |
We see no problem getting spreads for any of the CME group exchanges. We just got a listing of all of the spreads for NYMEX CL. These are the relevant instructions for this: Real-Time Exchange Data Feeds Available From Sierra Chart: Exchange Traded Spreads Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
