Date/Time: Sun, 24 Nov 2024 11:36:29 +0000
[Locked] - Errors in data when using -ALL data recording suffix
View Count: 190
[2024-06-04 22:08:48]
User785009 - Posts: 9
Maybe I don't understand what the -ALL data recording suffix does, but it seems to be creating false/synthetic data of some sort. >99% of the time there is no difference between not using -ALL and using -ALL. Then all of a sudden things go haywire and the -ALL suffix starts creating junk data.
Example:
6EM24-CME
2024/6/3, 16:23:10.011, 1.08915, 1.08920, 1.08915, 1.08915, 1, 1, 1, 0
2024/6/3, 16:23:17.368, 1.08915, 1.08920, 1.08915, 1.08915, 1, 1, 1, 0
2024/6/3, 16:23:18.417, 1.08920, 1.08920, 1.08915, 1.08920, 1, 1, 0, 1
2024/6/3, 16:23:18.446, 1.08920, 1.08920, 1.08915, 1.08920, 1, 1, 0, 1
6EM24-CME-ALL
2024/6/3, 16:23:18.447, 1.08915, 1.08920, 1.08915, 1.08915, 1, 1, 1, 0
2024/6/3, 16:23:18.447, 1.08920, 1.08920, 1.08915, 1.08920, 1, 1, 0, 1
2024/6/3, 16:23:18.457, 1.08915, 1.08920, 1.08915, 1.08915, 1, 1, 1, 0
2024/6/3, 16:23:18.457, 1.08920, 1.08920, 1.08915, 1.08920, 1, 1, 0, 1
So, the first line is exactly the same, then the -ALL suffix starts going crazy creating junk data.
I compared the data with other data providers and 6EM24-CME is correct and matches their data. But 6EM24-CME-ALL is wrong and junk data.
What exactly does -ALL do?
Thanks.
[2024-06-06 00:10:52]
Sierra_Chart Engineering - Posts: 17154
We do not know what is meant by junk data.
Our recommendation at this point is do not use that suffix if you do not understand what it does. At this point simply do not use it.
We do not need to be told it does not work properly when it does. A posting like this is a waste of our time. Being told there is junk data, and when you are using nonstandard functionality for whatever unknown reason.
Just simply do not use it at all. We are not going to provide any further help here.
We cannot help with your question. We do not know what you are asking about.
Documentation is here:
Data Recording Modes
But we are not going to answer any further questions.
Date Time Of Last Edit: 2024-06-06 00:20:19
