Date/Time: Thu, 19 Sep 2024 21:32:17 +0000
line properties
View Count: 979
[2014-08-21 00:45:21] |
User28682 - Posts: 233 |
Hi, I manually draw lines on charts and am wondering if I can make my style of lines a default setting instead of having to change them each time. I have looked in the "chart drawing properties" but cant find a place to elect a new default. Thanks Tom |
[2014-08-21 16:55:18] |
Yes this can be done through the Line Tool Configuration: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DrawingToolConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
